| Garage | .oRg Forums | Portal | Blogs | Arcade | Gallery | FAQ | Classifieds | Calendar | Chat | Mark Forums Read | Sponsors |
| | LinkBack | Thread Tools | Display Modes |
heck I ran a vulcanized rubber rope plug for at least 1000 miles of pretty fun riding.. (UncleSteve was there ) never had a problem with it... never even gave it a second thought... fix it and ride the thing... (make sure to trim the plug flush with tire please)______________________________________ Last edited by Mr Bogus; 10-29-2009 at 08:29 AM. |
I patched (not plugged) a fairly new tire,......rode it for 1500 hard miles. Like Mr. Bogus,.....I never gave it a second thought. When I replaced the tire,.....I checked the patch,.....and it appeared as secure as the day I installed it. Using the correct procedures and the correct products makes for a secure repair. Maintaining proper inflation and regular checks for cuts, abrasions, etc ,..........will give you long tire life,......and insure you keep YOUR life. Good luck with your repair!! ______________________________________ Buell Peg Mod for the Busa or B-King!! Click this link>>>> http://www.hayabusa.org/forum/member...sa-owners.html |
If you can't afford to fix it right leave it sit until you can, it will still be there when you get the money. I will not repair radial tires in my shop no matter what the customer says. I will help him out with a used tire if I have one or however else I can. I am sure you can find a decent used tire from somebody on here Make A Post.
That air compersor for motorcycles seems like a good thing just to have around. does it run off of the battery or something else?
'06 Busa Bazzaz Z Fi;two brother slip on's; K&N air filter 07 Busa 6" extended swing arm;60 wet shot of nx nos |
I've used fix-a-flat on past small injuries but never ride hard until the tire is replaced. Never had an issue, that doesn't mean you won't. Good luck.
Robert
I got a chance to go to EZ Rider the other day.. they charge 3bucks for the patch...40bucks to unmount/remount the tire I would do it if the tire had good life left in it! Posted via Mobile Device |
| Runs off the bike battery. Same concept as the mini ones that plug into car cigarette lighters.
______________________________________ '06 Blue & Silver PC3, TRE, Sm Airbox MOD, Full Yosh TRS, AFAM 17/42 Sprockets, EK ZZZ Chain, PP CT2's, R6 Throttle |
all my friends say i am crazy, but I will not ride on a patched or pluged tire, now my friends all do it on plugs, they have never had a problem. they all ride hard even with 2 or 3 plugs in there tires.
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| flat tire | highestgrade | General Bike Related Topics | 4 | 06-28-2009 03:17 AM |
| What's the best tire kit for a flat tire... | Over_Easy | Maintenance and Do-It-Yourself | 15 | 09-13-2007 02:36 AM |
| Flat tire | Avitar | Busa problems | 8 | 06-24-2006 01:42 PM |
| HELP...FLAT TIRE !!! | CMEPASU | General Bike Related Topics | 15 | 11-05-2005 02:31 PM |
| Flat tire! | cnjdawson | General Bike Related Topics | 14 | 08-20-2003 03:19 PM |
