Go Back   Hayabusa.oRg > Modifications > Busa Mods
Reply
LinkBack Thread Tools Display Modes
  #21 (permalink)
Old 07-10-2009, 04:33 PM
BigRod1300's Avatar
Hayabusa Master
Group: Members
Default Re: 300 kit brake bar
Dont forget the Pics of your new fatty and the event.
______________________________________
  #22 (permalink)
Old 07-10-2009, 11:23 PM
SKINN's Avatar
Professional Pilot
Group: Donating Member
I'm having some problems with the air ride, it works but it's slow... Do you have a diagram for the instant up? I think you told me compressor to tank, tank to pressure switch, then to valve controller... I need a picture...lol
  #23 (permalink)
Old 07-10-2009, 11:38 PM
SKINN's Avatar
Professional Pilot
Here are some iphone pics... I'll have some better ones after I get her cleaned up...!
  #24 (permalink)
Old 07-11-2009, 05:10 AM
BigRod1300's Avatar
Hayabusa Master
Group: Members
Quote:
Yep that with the air line. WHen turned on..power to the pressure switch relay...does compressor start to fill the tank? And then shut off when the pressure switch psi is reached? That gives stored air for when YOU hit the raise toggle. You have the Dapincci air-ride right. Make sure the compression ( stiffness ) adjust ment is empty when going to raise hight. IF that side is underpressure it works against the raise side and will be slower raise.
When I park to slam the ride.....I release the comfort side ( bike will raise some) then I release the raise/lower side, that drops the bike down to lowest adjustments. This will leave the air cylinder 100% empty for the quick pop of air to the raise side when you ready to leave and raise it.
Dont for get to adjust the threaded dogbone links to the air being 100% empty and the tail just off the tire. Keeps from any air lines misshaps ( leak ) from slamming the tail into the tire.
  #25 (permalink)
Old 07-11-2009, 05:15 AM
BigRod1300's Avatar
Hayabusa Master
Group: Members
That looks good. How long is your extended tail....6 inches? YOu may have miss wired it too. The compressor is ON by the pressure switch relay only. SO if your hitting the toggle and the compressor comes on.....not right! Compressor gets power from switch relay. Relay gets from battery or ignition. The goggle now ONLY triggers the air-ride valve controller.
  #26 (permalink)
Old 07-11-2009, 10:29 AM
SKINN's Avatar
Professional Pilot
Can you pm me your number...?
Posted via Mobile Device
  #27 (permalink)
Old 07-11-2009, 05:07 PM
SKINN's Avatar
Professional Pilot
Shop pics...
  #28 (permalink)
Old 07-11-2009, 08:18 PM
BigRod1300's Avatar
Hayabusa Master
Group: Members
Whats up with the last pic of the air bottle being there? PMed you my number to help.
  #29 (permalink)
Old 07-11-2009, 10:16 PM
SKINN's Avatar
Professional Pilot
That wasn't finished... But I did strap the bottle there... I'm gonna need some help with the instant up. The shop didn't understand, I was hoping you could take a look at it or talk to them. I rode it today, it rides nice... I love it...! Oh yeah the tail is 6 over...!
  #30 (permalink)
Old 07-12-2009, 02:11 AM
BigRod1300's Avatar
Hayabusa Master
Group: Members
Why not put that bottle in the tail? IT fits crossways between the subframe.
How did it ride?
  #31 (permalink)
Old 07-12-2009, 06:50 AM
SKINN's Avatar
Professional Pilot
It doesn't fit crossways, it would fit on the side of the sub... I have the tiger tail, so I don't have that much room under the seat... Help... The way it's set up now, I can't even use the pass seat...!
  #32 (permalink)
Old 07-12-2009, 06:53 AM
SKINN's Avatar
Professional Pilot
I love the ride, I'm sure I'll love it even more once I get it setup right...!
  #33 (permalink)
Old 07-12-2009, 07:00 AM
SKINN's Avatar
Professional Pilot
  #34 (permalink)
Old 07-12-2009, 10:40 AM
BigRod1300's Avatar
Hayabusa Master
Group: Members
That sure looks like the same 1 pound bot that I have......
Your in fairfax right. Im still not working right now....so most every afternoon is open for me is you'd like me to look at it?
  #35 (permalink)
Old 07-12-2009, 04:10 PM
SKINN's Avatar
Professional Pilot
Same bottle different tail... Yeah, I'm in Fairfax... How far are you from 22032...?
  #36 (permalink)
Old 07-12-2009, 05:25 PM
BigRod1300's Avatar
Hayabusa Master
Group: Members
Same subframe...but you have tiger-racing undertail tray (That service little to none now that you have the stretched fatty).* loosing trunk area and moving the space to under it* Move compressor above the subframe rail and also move the big all in one relay/pressure switch beside it. Put the bottle as indicated...between the subframe rails, under the undertail tray, between the passenger rearsets. The valve control is SO FAR away from the air cylinder? FIRE THAT SHOP!
Im in Hagerstown...guessing 1 hour or 1hr-15 min form Tysons corner area ( with NO traffic)!
  #37 (permalink)
Old 07-12-2009, 05:31 PM
BigRod1300's Avatar
Hayabusa Master
Group: Members
The Tigerracing undertail is great for those that have stock arms and are looking to slam it or get that squat off the line ( gives tire room ). You no longer need to do that. The space that was a trunk is gone, but that space is not under it. The bottle, realy/pressure switch, and even the valve controller should fit in that area. If you want to cover it then and keep it all neat and clean...get the catylist extended 6in undertail This will let you put your passenger seat back on then too. Guess the relay/switch is to high now for it being above the tigertail tray?
  #38 (permalink)
Old 07-12-2009, 05:39 PM
BigRod1300's Avatar
Hayabusa Master
Group: Members
this might help
  #39 (permalink)
Old 07-12-2009, 05:42 PM
BigRod1300's Avatar
Hayabusa Master
Group: Members
Sorry one more thing I just noticed. At the compressore....the way they mounted it = not good. IT will vibrate against the subframe and make very loud noise when on, and the band they used ( I know it comes with it ) will break in about 6 months. Get some rubber or isolation material between it and anything else. Use 2 large ( 1/4 inch wide) plastic tie straps to mount it.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
240 or 300 KIT pokitbusa Gen II Busa Information 9 06-29-2009 09:30 PM
300 kit . which one ? davidl9953 Busa Mods 7 02-18-2009 07:43 PM
330 tire on 300 kit dropem631 General Bike Related Topics 5 03-23-2008 06:10 PM
300 tire kit itzmatty General Bike Related Topics 7 02-07-2008 08:20 AM
any one got a 300 fat tire kit nuttinsmallboutdiz General Bike Related Topics 6 10-11-2005 12:26 AM
(c) 1999-2009 Hayabusa Owners Group
