Go Back   Hayabusa.oRg > Modifications > Busa Mods
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 01-07-2009, 11:48 AM
godzilla's Avatar
New Recruit
Group: Members
Lightbulb battery mod
due to some additional electrical systems in need more battery power. instead of using a second battery i decided to use a single big one. after some research i found the gel-gtx20 matching my requirements best. it has twice the capacity of the genuine busa battery and should solve my problems once and for all.
today i started the mod by welding a matching box using some stainless steal. the box will be mounted with the two scres next to the fuel-tank base. i donīt want to drill or modify the frame. the box is gonna get some black paint tomorrow.
on this pic you can see the battery is twice as long as the original busas cellpack when used lying whatīs no problem cause of the gel-layout. the smaller box is the one i used till today with the original battery.
tommorow iīll modify the undertray and hopefully finish the mod.
______________________________________
size does matter!
  #2 (permalink)
Old 01-07-2009, 11:53 AM
BA BUSA's Avatar
MotoGP Wannabe
Anime BlackJack Champion
Group: Donating Member
Default Re: battery mod
Cool, keep the pics coming
  #3 (permalink)
Old 01-07-2009, 11:57 AM
solarbarack's Avatar
Hayabusa Immortal
Looking goo bro. Post up some pics alo the way.
Posted via Mobile Device
  #4 (permalink)
Old 01-07-2009, 12:09 PM
Commuta_Busa's Avatar
Hayabusa Immortal
Enemy Shooting Champion
curious where exactly that's being mounted? Are you still running a stock boxed swingarm?
2009 Super Streetbike's Top Speed Challenge Winner
Unlimited naturally aspirated class
  #5 (permalink)
Old 01-07-2009, 01:26 PM
bowwow's Avatar
Professional Pilot
Group: Members
What is the price of that battery?
  #6 (permalink)
Old 01-07-2009, 01:41 PM
F.O.G. HOON
Thanks for sharing!
Love to see the finished product.
  #7 (permalink)
Old 01-07-2009, 02:53 PM
Cerberus's Avatar
Hayabusa Master
ZeroGravity Sport/Touring Windscreen - Harris 'Busa Grips - TL1000 Pegs - Tobin Seat - Devil High Mount System - Clear Alternitives Smoke Intergrated Tail Light - Ram Mount Stem Mount for GPS/MP3 Player - Black/Carbon Look Tank Bra - RoadLok -30 LED Switchbacks - Black Outlaw Racing Gear Lever & Rear Brake Lever
  #8 (permalink)
Old 01-07-2009, 04:51 PM
pashnit's Avatar
Hayabusa Immortal
Group: Site Sponsor
Very cool. Love to watch this one develop too. The Busa on a scale of 1-6 last time I looked was like a 1.5 on the electrical output that could be designated for heated gear, electrical mods, etc. Pretty low.
PashnitBusa.com --> Parts & Accessories for your Hayabusa
Questions? Email: pashnit33 at yahoo.com Tele: 530-391-1356
Read about the A-Z PashnitBusa Mods .:. PashnitBusa Discussion Forum on the Org
  #9 (permalink)
Old 01-07-2009, 04:55 PM
dadofthree's Avatar
Seasoned Beef
Will the charging system handle twice the battery
  #10 (permalink)
Old 01-08-2009, 05:02 AM
godzilla's Avatar
New Recruit
Group: Members
here we go. just back in time from garage.
i applied the box at the fuel-tank basemounts. there are two M8 bolts connecting the mount with the frame:
the mount of the battery-box have to be L-shaped, otherwise they woudnīt match:
hereīs the battery in underseat-view. ecu, cable, quickshifter, speedohealer a.s.o. still fit. the battery is not as high as the original one. fits perfect. thereīs also no need to rewire, all cables reach the new port-positions of the bigger battery:
the battery does not reduce wheel clearance. my bike is 5" over:
but this mod shoul work with stock bikes, too, cause there is much more space than 5" between battery and rearwheel. if you donīt lay on the ground the battery-mod is completely invisible.
the battery is just a few bucks more expensive than the original one. it is normally used in harleys and easy to get. but be sure to get a gel-one. simple acid units will not work in lying position. just check ebay or local dealers. i paid about $85.
charging will be no problem. in normal, daily use the charging system doesntīt need to work harder, cause the battery is not always empty and hasnīt to be fully recharged. if the higher capacity is used, it just takes a few more miles more complete charging.
apart from a little bit cosmetic work the mod is finished and iīm very happy to have more electrical power for all the funny things i love that much ;-)
size does matter!
  #11 (permalink)
Old 01-08-2009, 05:30 AM
UncleSteve's Avatar
Gear good - roadrash bad
Interesting, I have always wondered if that was possible , we have battery issues on our "work" Busa's.
Lord, Keep your arm around my shoulder and your hand over my mouth.
AMEN!
  #12 (permalink)
Old 01-08-2009, 06:09 AM
BusaWizard's Avatar
On a Steel Horse I ride.
Great idea, you may have upon hit on something.
If you're not living close to the edge, then you're taking up too much space.
Fast is easy. Quick is hard.
  #13 (permalink)
Old 01-08-2009, 09:06 AM
DR1300R's Avatar
Keep On Trucking
Way Kool.. The swing arm looks awful close, almost like it would hit when you sit on it.
Sweet mod..
Doyle #11311
2000 Low Budget Bagger
"On a steel horse I ride"
  #14 (permalink)
Old 01-08-2009, 09:46 AM
F.O.G. HOON
Thanks!
Nice write up.
  #15 (permalink)
Old 01-08-2009, 10:07 AM
rockadaous's Avatar
mod-a-holic
2006 LE
shinny stuff/small air box mod/P.A.I.R mod/GiPro/+1 bones/Yoshi R22's/muzzy fan/PCIIIusb/Pipecross air filter
  #16 (permalink)
Old 01-08-2009, 10:42 AM
twotonevert's Avatar
Member of P.E.A.
Mahjong Solitaire Champion
Group: Super Moderators
Quote:
I cant imagine why Steve.
Check out my videos on Vimeo
http://www.vimeo.com/12351394
Momma said, "Pledge is the devil!"
  #17 (permalink)
Old 01-08-2009, 11:23 AM
Hayabusa Immortal
looks like a good solution for the stretched crowd.
The way resolved the electrical problems on my buddies busa was by just adding a second battery. Yes, he does have an aftermarket tail so the battery box area did have additional room. You end up with the same voltage but alot more amps. The charging system has no problem keeping up with things.
  #18 (permalink)
Old 01-08-2009, 11:38 AM
godzilla's Avatar
New Recruit
Group: Members
Quote:
Originally Posted by DR1300R View Post
The swing arm looks awful close, almost like it would hit when you sit on it. ??
the photo is fooling. thereīs far enough clearance. iīll try to make a better shot.
itīs even more space than i had with the original battery. things on the photo may appear closer as they are ;-)
one of the main reasons why i took a big single battery instead of two in parallel mode ist the fact, that two batteries permanent connected discharge each other if they are not completely equal. if you use two batteries of different sizes you get exactly this effect.
size does matter!
  #19 (permalink)
Old 01-08-2009, 11:56 AM
DR1300R's Avatar
Keep On Trucking
So your saying with stock swing arm there would be no clearance issues, correct?
Link to battery or model numbers off it would be cool.. Also would you be interested in making a box for a small fee?
BTW Great write up..
Doyle #11311
  #20 (permalink)
Old 01-09-2009, 04:03 AM
godzilla's Avatar
New Recruit
Group: Members
this is the same i installed: eBay Motors: YTX20L-BS GEL Battery Buell Harley Polaris Bombardier (item 400018747067 end time Jan-18-09 08:21:34 PST)
dimensions can be found in disription, just check if thereīs enough clearance at your ride. i canīt guarantee this mod will fit any busa. but there are also smaller batteries which can be used if this one wonīt fit. 16AH e.g.
sorry, dude, but iīm german and sending parts to the united states from germany is very, very expensive. but iīm sure youīll find a guy who welds a box for little money, cause itīs not the difficult and donīt need much time to fabricate.
size does matter!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Mod to my Clutch Cover Mod RonnieTheBull Appearance mods 16 12-31-2008 07:04 PM
Battery Charging Mod Learjett Busa Mods 30 01-27-2007 09:56 PM
Air Box mod pics and valve mod sportrider1296 General Bike Related Topics 12 01-17-2006 10:59 PM
Small airbox mod, added to the mod MN72Busa Engine and Performance mods 5 08-20-2005 07:24 AM
Battery died. Whats the cost of new battery bs72069 Busa problems 15 01-30-2005 09:54 AM
(c) 1999-2010 Hayabusa Owners Group
