![]() New from APE, racing's premium crankshaft supplier, a new two millimeter stroker kit for '99 thru 07 Suzuki Hayabusas Kit consist of a brand new 08 Hayabusa crankshaft, but you can't buy this one from Suzuki or anyone else. Rod journals are fluted for extra oil at the rod bearings Micro polished Computer balanced to less than 1/3 gram. ( these cranks don't come from Suzuki balanced that well) This allows you to run this crank with the counterbalancer removed if you like Certificate of balance.. Spacer plate, allows this crank to bolt into earlier busas without changing rods or pistons. ( Use 08 main bearings ) When used with a 1397 motor, it yields 1441cc. These cranks list at $1040.00 from Suzuki Kit Special from APE $975.00 Outright. Options include counterbalancer gear removal and/or lightening. In stock, Call 661-256-7309 ______________________________________
Speed merchant http://www.hayabusazone.com |
| Thread Tools | |
| Display Modes | |
