Results 1 to 2 of 2
  1. #1
    Jay
    Jay is offline
    Seasoned Pilot
    Join Date
    Jan 2003
    Posts
    414
    Default Dual Gauge Leakdown Tester
    The Racetoolz dual gauge leakdown tester is a precision tool for measuring the amount of cylinder leakage in an engine. It will work on any internal combustion automotive or motorcycle engine with threaded spark plugs.
    The tester requires an external air supply of at least 100 psi.
    Simple to use. The adaptor hose screws into the spark plug hole and air supply is connected to the tool. The regulator is adjusted so the left gauge reads 100 psi. Any leakage is shown on the right gauge. If the right gauge reads 90 psi, that cylinder has 10% leakdown.
    In most cases, the tester can pinpoint the leakage help diagnosis damage before the motor is disassembled. For instance, if leakdown shows on the gauge, listening at the exhaust outlet may product the sound of escaping air. This would indicate leaking exhaust valve/s. In the air intake, intake valves. Oil fill, leaking rings, etc.
    Each leakdown tester comes with the precision measuring tool and one spark plug adaptor hose. Extra adaptor hoses as well as an extension hose is available.
    Kit Price, racer $112.00
    LDT1000-10 Leakdown tester with 10 mm hose
    LDT1000-12 Leakdown tester with 12 mm hose
    LDT1000-14 Leakdown tester with 14 mm hose
    For more information, visit RACETOOLZ.COM
    Racetoolz.com is a division of APE racing Products
  2. #2
    Jay
    Jay is offline
    Seasoned Pilot
    Join Date
    Jan 2003
    Posts
    414
    Default Re: Dual Gauge Leakdown Tester
    Need to keep our stuff on top
Similar Threads
  1. Fuel Pressure Tester
    By logang1k in forum General Bike Related Topics
    Last Post: 09-08-2008, 01:47 PM
  2. 30% leakdown,coolant in oil,shop wont check
    By whiteboy06 in forum Busa problems
    Last Post: 02-01-2008, 04:07 PM
  3. Compression and leakdown done!
    By OB_Lofty Abuse in forum General Discussion
    Last Post: 08-06-2000, 02:14 PM
  4. Leak down tester
    By OB_GSXRTURBO1 in forum General Discussion
    Last Post: 05-05-2000, 11:01 AM
  5. Leak down tester
    By OB_Jay in forum Modifications & Aftermarket Equipment
    Last Post: 05-04-2000, 10:27 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
