yea exactly u need C16 to ride and at $15 a gallon thats not laughable! and what happens when u run out of gas? no one is riding around on the street consistently with a 1630. maybe two miles to the car show and back smhWrong answers. Bob Carpenter builds up to 1630 for street use. Uses a 9 mill marine crank with Ty rods and zx14 bearings with no heat issues it has lower compression than his 1630 race motor for pump gas use but they make in the 250 rwhp range and are daily riders
I have his 1630 race engine and take street rides gets expensive with q16 fuel and I have no issues temp gauge stays in middle.
Get the right builder and you can do it. Brett
exactly!Where are you getting your info from?? On Bob's site no where does it say or advertise that his 1630 kits are streetable.... matter of fact he states with an asterisk that his 1470 kits are not recommended for street use. So if a 1470 ain't built for the street where are you getting that a 1630 is....???
again read it again
he has a 1630 gen 2 motor set up on pump gas! makes in the 250 RWHP range with street exhaust, again PUMP GAS
and with bigger bearings and crank and rods, this set up is super strong, no bearing issues with this stuff
great sleeper package,
a stage 1 turbo kit will make far more then that and live a hellova lot longer. but, I'm sure the throttle response is quite impressive with that 1630.
but ill give up a little throttle response to make 400+ hp to the wheels on PUMP gas cause that 1630 might jump out on a turbo bike but that will be short lived once the turbo bike starts makn boost and if its with one of the newer GTX3071/76 turbos it will be microseconds before that 1630 will get lost in the turbo bikes rear mirror.
the larger turbo bikes may take a second or so longer to build boost but nonetheless it will still put bus lengths on that 1630.
