Go Back   Hayabusa.oRg > Racing Forums > 1/4 Mile
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 03-20-2006, 02:36 PM
MidnightBusainSD's Avatar
Busa Rancher
Group: Donating Member
Default
THis is what my setup is now
VR stage 2 turbo setup with fully built motor
AMS1000 Multi stage Boost controller
4-6in over Swing arm
18/40 gearing with Shinko 200 Soft tire
Looking to be running up to the 300hp mark on the ground mabey a bit more if i decide to pump the race fuel to her but for now we gona keep her on the lower side.
Anyways just looking for some gearing suggestion for the strip
I thought i would try the 18/40 that i have now. Granted i have heard of 18/36? what do you guys think of that?
Granted now rember i weight in at about 345 with gear give or take some now
Any suggestions?
______________________________________
02 SE BerserkBusa 2.0 240 tire and stage 1 turbo stealth as we can get it.
Build thread
http://www.hayabusa.org/forum/busa-m...240-wheel.html
  #2 (permalink)
Old 03-20-2006, 04:15 PM
Default
I could be off base.... but I think you are headed in the wrong direction.
You need more gear for bigger riders.
I weight 220lbs (dry weight) and run 18 / 45 gearing with a very similar set-up as yourself.
I would suggest the same, or maybe even more aggressive gearing (ie: 46 - 48 tooth rear).
Velocity Racing Powered Turbo Busa
  #3 (permalink)
Old 03-21-2006, 09:15 PM
Professor's Avatar
Hayabusa Immortal
Group: Administrators
Default
Help me out here Cecil.
18/45 is essentially the same as a 16/40. I can understand why you wouldn’t want to run a 16/40 because of stress on the chain. Why not run a 17/42 17/43 which is within 1%. Is the 18/40 easier on the chain or are you picking the gear that close and trying to split in between the 17/42 and 17/43?
03 AE
2006 PMRA Street E/T Champion
2007 PMRA Street E/T Champion
Pipe and stock arm Fat Old man 9.90 @ 139.16
Room for improvement!
A bit longer and a bit of motor work 9.36 @ 147.39
  #4 (permalink)
Old 03-21-2006, 10:33 PM
fstbusa's Avatar
Default
I'm running stock gearing with stock wheelbase and 270hp
03 40th Ann. Ghetto Busa
whats a TRE?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
(c) 1999-2009 Hayabusa Owners Group
