| Quote:
But be prepared to be buying clutches if you plan on practicing alot You're 60 ft, could down a little bit but you are doing real good..which would give you a better time Keep up the good work and wear your gear ______________________________________
'03 Busa 6k HID kit * * * *pc3 Rizoma rearsets * *SpeedOhealer Vortex sliders * * *Gille Chain Adjusters Clear signals * * *Top Gun undertail Coerce CF Fender * * Tobin Seats Pair Valve removed * *Galfer lines ABM Rotors * * Sportvue MC1 HUD HMF Dual High Mount * * BMC Race filter |
Kool..9s are good for the first/second time out!! Like said..get your 60's to low 1.6's and you will go better!! Have fun and good luck!! ______________________________________
2000 HAYABUSA Blue/silver 8 second street driven showbike!! 2007 GSXR1000 VELOCITY TURBO Sponsored By Veterans tree service and Caruso tile 2007 GSXR1000 New toy lots to come!! 2004 GSXR1000 Blk/silver a little bit of bling and a extra 35hp of zing!! *FOR SALE* |
And I run 17-42..I think its perfect!! Come out at like 5-6k and you will fly..You do have it strapped and lowered in the back?? ______________________________________
thanks for the words of encouragement,the bike is strapped in the front,but only down 2'' in the rear because i have been riding it to the track,also filled the tank both times still had over a half a tank when i got home,next time i will take it in my truck,so i will lower the rear 3'' and light fuel load,which should help,i had a new map in the bike this week which was better on the bottom and the middle but i think a bit rich on top,i will try a few tweeks on that,the reason for the low launch rpm was to just get used to launching again,the low revs made it much more comfortable for me to pin the throttle quickly without any drama (at least i remembered to grip the bike with my legs this time) next time out i will try to step it up a bit,but nothing drastic,just want to enjoy relearning how to launch a bike again,if the 60's improve a little bit each time out and i am having fun i can't ask much more then that
well... i havn't been to the track since i made this post a year ago,and the bike hasn't changed much,other then the dry nitrous setup,and muzzy can bolted on to the yosh exhaust (the mid pipes are the same size,but the muzzy can has a larger core,and is a bit shorter) i have a few parts on the way in preperation to run it on the bottle,a 3-9 '' arm and ek zzz chain,i will probably go with a shinko,the unknowns right now are where i will set the w/b,gearing and jet,i think,for the juice to be effective,you have to spray it early,i would like to set the btc box for 1st gear,with the 2 dial (easy to say,may be a little harder to do) i will most likely go conservative on gear and jet,and about + 4'' for the track,it will be a few weeks before this comes together,any thoughts are welcome |
| Quote:
2006 Busa Black/Gray Mods: Kickstand, Hump Grab Bar, Tiger Racing Hump Storage Pingle Dogbones/Bushings, PC111usb, GIpro ZG DB Screen, Brock Gen111 megaphone Brock Pair Valve, Billet Clutch, and Clutch Cushion Small Airbox, 4-7 Swingarm Extension 16T Frt, EK530DR2 Chain, PMR Kill Switch Cycle-Tek Co2 Shifter, Shinko Ultra Soft BoostbySmith Launch/Shift light Clear Alternatives integrated tail light TMH Billet Sprocket cover, TMH undertail NOS next..... |
| Quote:
| Thread Tools | |
| Display Modes | |
