Tethered Kill Switch
bronc3
Does anyone make a plug-n-play kill switch for the Busa? All I've found so far are the hack-n-butcher universals.
oh come on... you open up the throttle assembly to get at the kill switch wire and splice the tether kill into them. It takes probably 30 min to do. Very easy. If you ever decide to remove it just reconnect the wires inside the assembly.
btw I have never seen a plug n play kill switch besides putting a screw into your kill switch button to have a redneck style kill.
Just bein' picky I guess. Don't like cutting in to harnesses, even though the kill switch on the bars is REAL basic. Guess I'll have to bite the bullet to be legal.
you just could strap your arm to the handle bar to make sure you never need the kill switch.. worst comes to worst.. your hand will still be there to hit the kill button..
How about this one?
<!--EDIT|Krieg
Reason for Edit: None given...|1109561634 -->
I have one from schnitz racing.....nice construction, looks good, and easy to install.....all for $45!
