Wow that's easy once you "blip" the throttle thanks guys.
Flip your shifter around to GP style and it gets even easier. Pull up sucks in so many ways. I just press down on the shifter and blip it.
Load the shifter up before you blip the throttle.
Yup. Get your foot on the shifter and put pressure on it. When you blip the throttle it will go into the next gear without you thinking about it. Just remember to release the pressure after it shifts so that it will select the next gear when you repeat the process.ok, what is preloading? Is it putting pressure on the shifter before the blip?
